1996 850 Where is Signal relay "Flasher" ?
Old Oct 12, 2010 | 08:49 AM
rgastuart's Avatar
Default 1996 850 Where is Signal relay "Flasher" ?
Where is the signal relay or flasher located for a 1996 Volvo 850? I went to autozone and they said it should be by the fuse box but I don't think that is correct. Is a signal relay the same as the flasher? I understand it should be an easy fix but I can't find the flasher or signal relay for my car. Thanks for your help.
Old Oct 12, 2010 | 09:06 PM
The hazard switch is the relay.
Old Oct 12, 2010 | 10:01 PM
What is the actual problem? Symptoms? That hazard switch is about 6" long compared to the 1" deep other switches.
Old Oct 13, 2010 | 06:57 AM
rgastuart's Avatar
The Signals and Hazzard lights are not working. There is no sound or lights flashing. I checked the fuse box under the hood on the drivers side for the small ten amp fuse and changed it but I still do not have signals. I read around and they mentioned the signal relay. Thank you.
Old Oct 13, 2010 | 07:30 PM
91shelby's Avatar
it is located under the drivers side under dash cover, i believe 2 t25 screws to remove the cover and the location will be nestled up to the left
Old Sep 11, 2012 | 11:40 PM
Is the turn signal flasher part of the hazard switch or are you saying it's under the drivers side dash ??
Old Sep 12, 2012 | 02:38 AM
ibified's Avatar
I think there are 2 separate flashers, one for turn signals and one for hazards. Hazard flasher is built into switch and turn signal flasher is under dash.
Old Sep 12, 2012 | 09:29 PM
gdog's Avatar
According to my schematic there's only one flasher and it's integrated into the emergency flasher switch as tech said. Usually when you have a flasher issue the emergency flasher switch is the problem.
Old Sep 12, 2012 | 10:30 PM
I went out tonight and I'm pretty sure it's the $100 flasher switch that is controlling the turn signals. I didn't see a separate flasher anywhere in the wiring schematic either.
Time to go to the junk yard and get one to perform surgery on to see if I can piggyback an electronic turn signal flasher so I can run LED's. I can't get with the idea of installing resistors that run hot, need a safe installation spot, eat up electricity and add to the cost of the conversion when a lot of the reason is to save electricity and load on the alternator.
Any chance anyone has opened one up already
Attached Thumbnails 1996 850 Where is Signal relay "Flasher" ?-turn-signal-flasher-850.jpg
Old Sep 12, 2012 | 11:39 PM
ibified's Avatar
If you need one and cant find one at the junk yard, let me know and I'll see if I can snag you one this weekend when I go.
racernick
Jun 20, 2022 09:43 AM
honeyfixthecar
Jun 7, 2009 06:17 PM
honeyfixthecar
Jun 5, 2009 03:29 PM
gillet01
Jul 2, 2006 01:21 AM
castiron
Sep 30, 2005 09:03 PM
