1997 850R Speedo isssue & ABS light on
I have no speedometer. ABS module was repaired and sent back when it did not fix problem. They checked it again and confirmed it is working properly. Have not taken it in to check codes for ABS system. No issues with pedal, not mushy, trac light on also. What should i check next? I am thinking transmission speed sensor.
I would check the following:
- Wheel sensors.
- Wiring going into the top of the cluster.
Do you have a CEL? If so, you may want to take the car to a Volvo dealer to have them diagnose it.
- Wheel sensors.
