1997 850R Speedo quit
Old Mar 7, 2012 | 05:56 PM
jbuck's Avatar
Default 1997 850R Speedo quit
All other guages work speedo just quit working today. Change odometer gears 3 months ago. Any ideas? Car runs perfect.
Old Mar 7, 2012 | 06:13 PM
kwalshy's Avatar
check out this link; it may be of some value to you:
1996 Volvo 850 Turbo: Speedometer..I believe I have replaced vss - JustAnswer
Old Mar 7, 2012 | 06:41 PM
ABS light on?
Old Mar 7, 2012 | 08:04 PM
058ovlov's Avatar
Old Mar 7, 2012 | 11:07 PM
matt01's Avatar
check your fuses too
Old Mar 8, 2012 | 03:04 PM
jbuck's Avatar
ABS light comes on every so often. I had ABS module repair done 6 months ago. Fuses are all good.
Old Mar 8, 2012 | 03:10 PM
Mad Matt's Avatar
If you really need a new ABS module, go here!
https://www.midwest-abs.com/
You'll be very happy you did...
The owner is Matty Moo from Volvospeed. Very good reputation in the Volvo community.
Old Mar 8, 2012 | 07:58 PM
If the module was repaired double check the plugs to the module.
jbuck
Apr 23, 2014 10:15 PM
850rt5
Dec 6, 2013 05:46 PM
Hi555
May 31, 2013 10:00 AM
rich nc
Jan 28, 2010 07:25 PM
