2 questions
Old Jun 30, 2006 | 03:48 PM
fast850r's Avatar
Default 2 questions
First of all, how difficult is it to replace the gauges in my 850? Next, I have to replace my left rear caliper, and can NOT break loose the nut on the line that goes from the caliper to the junction. It is a solid metal line, not rubber. Can it be replaced with stainless steel lines? Or is this something I need to get from dealer. Because the head of the nut is getting chewed up trying to break it free.
Old Jun 30, 2006 | 04:43 PM
S70driver's Avatar
Default RE: 2 questions
ORIGINAL: fast850r
Why do you need to replace the gauges in your 850? What are you replacing them with?
Old Jun 30, 2006 | 06:27 PM
fast850r's Avatar
My fuel gauge does not work. I have replaced the sending unit in the tank, but nothing. figured I'd just buy the whole gauge setup and swap it out.
Old Jul 1, 2006 | 10:08 AM
Are you trying to use a good pair of Visegrips on the line now?
I believe you will need to replace with a metal line.
You should be able to buy from the Auto parts store. But it will be straight and you will have to bend it.
Note:Be careful bending it and don't kink it.
What I always do is where there is a Bend and I need to bend. I bend around a socket to make sure it doesn't kink.
Phil 850
Jul 25, 2012 10:01 PM
AnEskimo
Sep 25, 2010 08:32 AM
