2004 S60 16T Swap into 850
Hello all, I have a 95 850 turbo and am looking to potentially upgrade the turbo (15g conical), or rebuild the current one using a spare hot side off a 13g with the more desirable flange (I believe it’s angled but it’s been a while I would have to look). I don’t have a doubt that the hot side housing swap with a rebuild will work for what I’m trying to achieve, and I have a downpipe for it, but I also have a S60 16t sitting around that could use a rebuild. Is this pretty much an interchangeable turbo? I’m not worried should bolting to the engine as I’m using and S60R manifold, and Both will bolt right up, but what about exhaust options? Is the flange the same? Coolant and oil lines the same? Thanks in advance.
