2004 S60 AWD 2.5T Turbo Swap (K24)
Old Apr 14, 2018 | 12:50 PM
Jrstedham12's Avatar
Default 2004 S60 AWD 2.5T Turbo Swap (K24)
Hi so I have a Snabb FMIC and intake, 3" OBX downpipe, and IPD Turbo Control Valve already installed. Got some new vacuum lines from IPD I haven't installed yet. I also picked up a Borg Warner K24, and plan to install soon. All set to make adjustments to upper charge pipe and turbo inlet from Snabb. Everything else appears to be bolt on, but I keep reading that I'm going to have to redo my plumbing. From what I can see it looks like it will just line up. Is this not the case? Anyone have experience with this swap.?? Help would be greatly appreciated. Once I take my TD04L out, I want to make sure I have everything I need to make the K24 work. Planning on following up with an ARD or Hilton tune immediately after.
Old Apr 14, 2018 | 02:55 PM
tony1963's Avatar
I'm not sure what your question is, but it sounds like you spent a fortune to get maybe 15 more horsepower.
Old Apr 14, 2018 | 03:18 PM
I didn't spend a fortune, and I did all the work myself. And like I said, I'm getting a tune after the K24 is installed, which will put me at a hell of a lot more than 15hp. The question was whether or not my 2.5T oil and coolant lines will be compatible with the K24.
Old Oct 17, 2020 | 02:11 PM
Logan B.'s Avatar
Any luck with the swap? I know this post is old but I’m planning on doing the same thing.
1997GLT
Sep 13, 2020 10:19 AM
JayS60awd
Apr 24, 2019 08:10 PM
Jrstedham12
Apr 1, 2018 09:21 PM
Bpc576
Jun 4, 2017 06:10 PM
beazyco
May 9, 2011 06:09 PM
