2nd 12 Volt Receptacle
Hey guys,
Wondering if anyone has ever installed a second 12 volt socket and where you pulled your power wiring from for it. What would be the best way to do that, and where would you recommend pulling power under the dash? I want to have a second one dedicated to my valentine 1. Yes I know there are splitters. But I run my laptop off the other one and would blow fuses like none other running both off the one socket.
Thanks
Thanks
you can find the sockets on eBay. I'd probably splice into the circuit at the socket in the ashtray and run off that fuse. you may be able to install the new socket inside the console.
