850- 1994
hello veverybody...
I just wonder if somebody can help me with a problem on my volvo?
When the engine is hot and i stop it and will start it again it starts but just for a while it iddles and then it dies?
No problem when it´s cold,then it runs like a dream...
I have clean the house and checked all vacuumtubes...
Hope that someone can give me some advise..
Gugge
Gugge
It sounds like a fuel delivery problem. The fuel pump relays get temperature sensitive as they begin to die. The next time it dies use a rag to catch any spray and check for fuel pressure on the schrader valve on the end of the fuel rail. Be careful not to spray gasoline in your eyes, if you have safety glasses wear them. If the fuel pressure is good it should squirt out with good pressure. If it just dribbles out then there is a problem with the fuel pump or the relay.
...Lee
...Lee
Ozark...mine was doing the same thing (no offense) , and my recommendation is....
1. Clean the throttle body
2. Clean the IACV
3. Clean the MAF...
In my case the Maf was the clincher, but each of those did make a difference...
GL
Any Codes?
2. Clean the IACV
3. Clean the MAF...
GL
Any Codes?
My gut said MAF until the temperature came into the equation. My MAF problems have never been temperature dependant, my fuel pressure problems have always been in the shoulder season between hot and cold or visa versa. At least we have given gugge some things to look at and no expensive parts are involved - yet.
...Lee
...Lee
Check what Ozark said, my problem was not temp dependent...I see in re reading your post he was right the temperature dependency is an issue with your car. Although cleaning those things don't cost anything and is never a 'bad deal'...so before you reply, double check Ozarks idea also...
Best of Luck
Best of Luck
Hello again..Sorry that i haven`t written before...
I just want to say that you where right orzak,it was the fuelpump relay that was my problem.Now it´s running like a dream.
Thanks for all your´e advise......
Have a great time.....
Hope to hear from you soon again...
Regards
Regards
cmercon
Jan 19, 2009 09:00 PM
