850 angel eyes need some help
hi guys i have finally got my angel eyes to show off the halo effect. the problem is when my light switch is on daytime running it is the low beam and halo effect that is on instead of just the halo effect. i talked to a guy at ipd.com and he says there is a tiny screw that i can depress on the light switch and i can program which lights will be on by turning this tiny screw, but mine is actually looks like a tiny button does not look like i can turn it.has anyone ever played with this screw/button? mine is on the bottom right hand corner.
https://volvoforums.com/forum/volvo-...hts-off-52796/
Check this thread... You have to push in the **** then turn
https://volvoforums.com/forum/volvo-...hts-off-52796/ well that helped. the problem is i do not have that screw, i thought it was a button but it is capped i will try and take the cap off and see if there is a screw under it. but most likely not. i have a pic but ihave not figured out how to put it up on here or make an album yet but thanks for the help guys
Canadian vs. USA models. The daytime running lights are mandatory up north so there is no option on Canadian spec cars to do this. So chances are, you won't find the switch your looking for at a junk yard local to you.
You should look over on Volvospeed in the classifieds section to see if you can find somebody in the USA with the correct spec light switch that you want. Or call up V&S auto dismantelers in California to get the part.
Volvo & Saab Auto Dismantlers - New and used car parts
Ask this guy if he has the light switch. He's parting out a '96 850R...
http://forums.swedespeed.com/showthr...-850R-part-out
TacklaNHL
07-31-2012 10:35 AM
