How to keep lights off?
Old Apr 20, 2011 | 04:50 PM
t0mmy024's Avatar
Default How to keep lights off?
I was wondering how to keep my headlights off during the day without parking lights. I move the switch to the off position and its still on. Can someone please help me on this? Thanks!
Old Apr 20, 2011 | 04:59 PM
ibified's Avatar
Does your headlight switch have a small slotted opening on it? if you turn that with a very tiny flathead screwdriver, it should turn them off.
Old Apr 20, 2011 | 05:02 PM
MattyXXL's Avatar
Small screwdriver in the circled **** in the pic... Push in and turn. Lights will go off now..
t0mmy024's Avatar
Not sure if it does i cam check
Old Apr 20, 2011 | 05:54 PM
t0mmy024's Avatar
Thanks Matty! I have that however the previous owner messed it up so i cant turn it. How do i take the control itself out?
Old Apr 20, 2011 | 06:26 PM
boxpin's Avatar
It wont turn if you just turn it, you have to push it in then turn it.
ibified's Avatar
I dont think you can remove just the control - it's an integral part of the switch. You may have to go find one at a salvage yard somewhere.
Old Apr 20, 2011 | 09:32 PM
vjaneczko's Avatar
I think they made two versoin of the switch. If the one on the front doesn't turn, pull the switch out and check for one on the back.
Old Apr 23, 2011 | 11:43 PM
Elchopperfreak's Avatar
You can remove the headlight switch and open it if needed, if you push the mentioned slot too much, thers a good chance you will hace to open.. Also watch out for two copper "brushes" contact points, so you dont loose them, nor the tiny springs
_val
Jul 29, 2013 10:03 AM
ramon
Jun 6, 2013 12:27 PM
Newport_j
Dec 26, 2011 03:54 PM
dotse
Aug 21, 2011 09:37 AM
chrystald423
Mar 27, 2010 08:05 AM
