850 fuel gauge
My fuel gauge is not working, does anybody know what the ohms are for the fuel sending unit so I can check it, also is there a float in the fuel pump that sends signals to the gas gauge. I checked the wires from the sending unit to the gauge and their fine, it could be my gauge and if so, does anybody know what after market gauge I can use with a gauge pod. thanks for the help
The sensor range is from 7.5 Ohms to 327.5 Ohms, depending on how much fuel is in the tank. The fuel sensor is not in the fuel pump, it is its own unit and it is located next to the fuel pump, more toward the center of the car.
Depending on the year of the car ('93-'95) there are diagnostic test you can run on the instrument cluster from socket A-7.
...Lee
...Lee
Grab a copy of the factory service manual from here:
http://www.matthewsvolvosite.com/dow.../Volvo_850.zip
Once you unzip it see the file named instrument panel.pdf. It will guide your through the test procedures.
...Lee
...Lee
does that mean I need to replace the fuel sending unit
![](http://img182.imageshack.us/img182/2277/fuellevelsenderbeforewe4.jpg)
In your case I think I would check salvage yards for a replacement and pick up a newbase seal.
...Lee
J. H. McCharen
05-26-2014 11:26 AM
bartman
09-04-2008 08:35 AM
bartman
09-02-2008 01:46 PM
