850 Manual On Car Shift Knob Removal Write Up With Pics
Old Mar 10, 2011 | 08:48 PM
matt01's Avatar
Default 850 Manual On Car Shift **** Removal Write Up With Pics
This is how you remove a 850 Manual Shift ****
First here is it intact.Name:  1.jpg
Remove the door under the handbrake
then you stick your finger into the whole and hit the shift boot release.
For the next section i made a tool out of 1/2" copper pipe to stick up and release the 3 clips of the boot.
just cut the pipe in half and file down the tip
so you insert the copper tool and force it upward with a vice grip. When it goes up under the clips, it takes a good shot to take the boot down
Then you clip a good vicegrip onto the shaft about 1" below the ****
Then you get a second vice grip and put a rag between the **** and the second vice grip. The pry up on the ****
bob's your uncle the **** pops gently off.
Old Sep 30, 2011 | 01:54 PM
Lulumike's Avatar
Two questions, Matt. When you say: "so you insert the copper tool and force it upward with a vice grip. When it goes up under the clips, it takes a good shot to take the boot down", what are you hitting? The copper pipes upward? and with what? (I gather you have to hit both clips the same time or it wouldn't work, hence, the copper pipes on both sides?) You can't just hit them with a flat head screwdriver and hammer? Thanks. Great pics. Makes it very clear.
Old Sep 30, 2011 | 04:51 PM
matt01's Avatar
you have to hit the copper tools up into the shift **** boot clips. Then once your sure the tools have gone under the boot clips, you have to hit down on the shift boot.. It might take a good hit.. i think i wrapped it with a rag and lightly hit it with a mallet..
Old Oct 8, 2011 | 04:41 PM
Lulumike's Avatar
Default shifter ball seat removal
Matt,
did you manage to get the seat out? I finally got it out but cannot put it back in where it grabs the ball at its bottom to keep the shift in place. I've tried a bamboo tube (since I had no pipe) over it with a rubber mallet, so on, but it goes down only so far. Have you managed you do that yet?
Old Oct 9, 2011 | 12:10 AM
matt01's Avatar
you talking about the " ball seat" the white piece of plastic with 2 clips on either side that clip on the aluminum case. Yes, i got that on, honstly it was much harder to do that than the entire rest of the job put together.
I got it on with my hands i forced on it till i was red in the face and my hands were in so much pain. But i got it.. since then ive heard that the best way is to actually remove the entire assembly and install it with a clamp.
option 2: you can try heating it a little with a heat gun maybe it'll soften it up a little.
it seriously takes the strength of 10 men!
Old Oct 9, 2011 | 04:14 AM
Lulumike's Avatar
Default ball seat removal and installation
That's what I was afraid of: it wasn't easy taking it off either. Should have left the old one on even if it were cracked since it would never have come out from just shifting the gears. But it's out now and the new one doesn't want to go on. I tried putting the seat in hot water but still didn't work. I would hate to take out the whole assembly as it looks like many other connections have to be removed. I'll try your "red in the face" method. It's now about an eighth of an inch away from snapping in place but it's so tough. Thanks
Old Oct 9, 2011 | 10:07 AM
matt01's Avatar
i think at one point i opened the sunroof and stood on it!
Old Oct 9, 2011 | 07:55 PM
Lulumike's Avatar
No sunroof on mine: maybe I should cut one out to put the ball seat in? Ha! Ha!
Old Oct 9, 2011 | 09:01 PM
boxpin's Avatar
@matt01
Is this thing a sticky yet? I have referenced it in three threads but could not find it.
Old Oct 9, 2011 | 10:20 PM
If you guys think this is the best way to deal with it I can post it in the DIY thread?
Old Oct 10, 2011 | 01:39 AM
boxpin's Avatar
I think its worthy
Old Oct 10, 2011 | 10:07 AM
Done...
Old Oct 10, 2011 | 05:41 PM
matt01's Avatar
well.. i know that its better than the way volvo tells us to do it.. its much cheaper too!
thanks
Old Oct 12, 2011 | 12:05 AM
Lulumike's Avatar
Elsewhere (Volvo manual) the ball seat is "tapped" back in with a tool. I can't upload the pics since they're considered too big.
Old Oct 12, 2011 | 08:54 AM
Resize them with the windows resizer tool or some other graphic program.
Old Oct 15, 2011 | 04:33 PM
Lulumike's Avatar
Well Matt. A Volvo mechanic lent me the official volvo tool to tap the ball seat back into the gear housing area. But I manged to only crack the seat and now has to be towed to volvo. My advice: don't fool with the ball seat even if it's crack as long as it's in place. It'll never come out from just shifting. By the way, I can still shift to different gears so should be able to drive it to volvo but don't want to mess with that. Do you know if shifting it with the engine on (to put the car in a position for the tow truck to take it) will ruin the transmission or gear box? Thanks
Old Oct 15, 2011 | 06:11 PM
  #17
matt01's Avatar
its impossible to damage anything, since its cable driven..
I drove my car 2 days with a broken ball seat.
Old Oct 16, 2011 | 02:24 AM
  #18
Lulumike's Avatar
Matt, that's good to know. But was the ball seat still in place? Mine is totally removed so the shift has no tension whatsoever.
Old Oct 16, 2011 | 01:23 PM
  #19
Lulumike's Avatar
Matt, thanks for letting me know. I did manage to drive (back up) the car out of the drive way without the ball seat and the stick shift like a wet noodle (no tension whatsoever) but it still engages the gears. Now do I have the guts to take it on the highway down to Volvo itself? All this suggests that some sort of retaining gizmo to keep the shift more or less vertical, other than the $60 ball seat from Volvo will actually work.
Old Oct 17, 2011 | 03:56 PM
  #20
matt01's Avatar
with it complelty removed it might be hard.. when i drove mine the inside part was still there the top part ( clip ) was completely gone. i found that you have to push down on the lever as you shift..
