850 nonturbo dies at highway speed
Old Jun 3, 2016 | 07:00 AM
atsharp's Avatar
Default 850 nonturbo dies at highway speed
My 95 non turbo 850 will randomly die at highway speeds. After sitting for about 1 min it will start & run fine. Any help would be greatly appreciated.
Old Jun 3, 2016 | 08:07 AM
firebirdparts's Avatar
I had a few bouts of that with a bad cam sensor. It might set a code if that is the problem.
Psaboic's Avatar
Check fuel pressure and the fuel pump relay. Also try changing the fuel filter for starters
Old Jun 3, 2016 | 08:10 AM
I set a fuel pump relay jumper during my troubleshooting phase. My DD was also a 95 non-turbo. My car is a 5-speed, so if it quit on the highway, I could give it a really long time to recover, but there were plenty of times it wouldn't restart until "later".
Old Jun 3, 2016 | 09:26 AM
atsharp's Avatar
Mine has the older code reader where you move a wire into different plug ins. Not showing any codes
Old Jun 3, 2016 | 09:29 AM
atsharp's Avatar
It might happen maybe once a month & will start back up 1 min or so later. I could be wrong but I thought that maybe if it was electronic it would either work or not. But I'm not very electronically inclined
Old Jun 3, 2016 | 12:20 PM
I agree with you. I am just saying my cam sensor went through a phase where it would die and restart, and it turned out that was definitely the problem. However, it didn't take all that long to get worse. I didn't drive it 2 years like that. Good advice above about the fuel pressure too. If this thing only conks out once a month, that might be tough to diagnose.
Old Jun 3, 2016 | 03:52 PM
boxpin's Avatar
Dying fuel pump will give the same symptoms.
MrD1
Jan 22, 2020 09:31 PM
jayson44
Apr 11, 2013 01:52 PM
SCVolvo
Dec 15, 2009 12:09 PM
huzzsaba
Mar 27, 2009 08:45 AM
Systek
Nov 17, 2007 12:47 PM
