850 Revs high at cold start.
Old Apr 18, 2009 | 09:51 PM
onmidnighteyes's Avatar
Default 850 Revs high at cold start.
I started my 850 R yesterday morning and it took it a good bit to start and when it did it barely started and then went up to idle. I went back inside to let her warm up when i heard the revs go way up and just hold there. I walked outside and it was holding at about 3500 RPM. I shut it off, waited a sec and tried to start it and it wouldn't turn over. I got it started after a while and then it was fine for a sec then the revs went right back up again. It did it a few times yesterday and once again this morning. I took it to my friend and we put the scanner to it and the oxygen sensor was throwing a code saying that the car was running too rich. I've checked a couple of sites and some say it's a vacuum leak somewhere. Anyone else heard of this?
Old Oct 22, 2009 | 04:00 PM
clawless's Avatar
Default had this problem
it was the coolant temp sensor....mine the the same thing, it was running fine and all of a sudden - the exact same symptoms you mentioned happened. guess the sensor shorted to ground so it must have though it was REALLY cold.
Old Oct 23, 2009 | 09:51 AM
fcpgroton's Avatar
Former Sponsor
^^^ This sounds logical. If the sensor goes, it will make the car run very rich because it is trying to warm up the engine. I would have thought you would have had a code for the coolant sensor too.
I would check for vacuum leaks first, and if everything looks good there, then replace the coolant sensor.
JeannieBeannie
Dec 28, 2017 08:32 PM
Tricky850R
Oct 17, 2010 03:06 PM
Island Girl
May 3, 2009 02:17 PM
markjenross
Nov 7, 2007 08:02 PM
