850-T COOLANT HEATS UP
Old Nov 15, 2004 | 03:30 PM
ajju's Avatar
Default 850-T COOLANT HEATS UP
Hi All,
I a proud to join this site . I have a 96 model 850-T since a year .Today suddenly while tracelling , I saw hot steam rushing out from the place. I took it to a mechanic who suggested replacing the spark plugs , but that doesn't seem to solve the problem . Donno what to do. Can anybody suggest a solution and what could be the problem .. THANKS!!!
Old Nov 15, 2004 | 10:00 PM
Default RE: 850-T COOLANT HEATS UP
A little more info please!
Old Nov 16, 2004 | 03:22 AM
ajju's Avatar
Thanks !!!
I will await your reply . Someone also told me it could be the leaky cap from where you put the coolant. But does the coolant/water mixture boil !!!!!!!
Take care ...
Ajju
Old Nov 16, 2004 | 11:26 PM
Your bottle could be cracked causing it to leak and omit a little steam.Or if it has been topped off recently it could of just released some coolant.Also i would check your thermostat if it is bad it will build to much pressure and boil over.
Old Nov 20, 2004 | 02:44 AM
ajju's Avatar
Thanks a lot!!!!.I will have it checked as I am not sure where the thermostat is .On the surface there are no cracks at all.
Thanks again...
Old Nov 20, 2004 | 04:14 AM
ajju's Avatar
Hi Tech,
Now that I remembered , the service light is always on in my car for 2 mins when i start. I remember the last time i took it for service , the guy told me not to worry about it .( After servicing the car !!!!) How do you reset this light ?
Thanks !!!!
Ajju
Old Nov 20, 2004 | 10:31 AM
The thermostat is on the engine where the upper radiator hose meets the engine.There is 2 torxes 40 screws holding the thermostat housing on you need to remove them and the thermostat is under there.The service light needs to be reset with a reset tool.
Old Nov 22, 2004 | 01:25 PM
guptash's Avatar
Hi Tech,
How expensive is the reset tool and is it relatively easy to use?
Old Nov 22, 2004 | 02:49 PM
Im not 100% sure of the price but I think it is expensive.The light goes off after a little but if you can live with that then you don't need it.
https://volvoforums.com/post.asp?do=...137&toStyle=tm
Follow this link it is for the reset tool.
Old Dec 5, 2004 | 09:51 AM
ajju's Avatar
Hi Tech,
thanks for the reply, but the link you have provided goes directly to a message compose window .
Enjoy!!!
Ajju
Old Dec 5, 2004 | 11:09 AM
http://www.ipdusa.com/ProductsCat.as...564&RootID=629
Try this link.Sorry it didn't work last time.
taylor.j
Oct 23, 2015 12:46 AM
carson850
Jan 7, 2014 02:08 PM
dman777
Nov 6, 2011 01:58 PM
misspaularsmith
Dec 28, 2010 09:54 AM
timk
Nov 16, 2007 08:33 PM
