850 t5
did they only turbo the t5? also the speedo only goes up to 150 that just doesnt seem right.
In 1994, the 850 only came in two levels, base 850 (N/A 2.4L 5-cyl 168hp) or Turbo (2.3L 5-cyl turbo 222hp).
Here is the Wiki article on the trim levels: http://en.wikipedia.org/wiki/Volvo_850#Trims_.28U.S..29
You can cross check the VIN with Carfax too.
You can verify on the Volvo site: http://www.volvocars.com/us/top/comm...yourvolvo.aspx
Or just check your vin here on their site:
https://www.customers.volvocars.com/...C/vin1994.html
If the vin has a 57 in after the 6th position it's likely the 2.3 20 Valve T5 motor.
