850 t5 heater middle control knob not working
Old Aug 31, 2013 | 04:08 AM
john12345's Avatar
Default 850 t5 heater middle control **** not working
i have an 850 and the other day i went to adjust the heater control to get the air to blow on the front window. it was really stiff to turn the centre **** in the up right position. so i twisted it with force and it went really loose now the heater control is not working properly the air comes out the main Vents and the **** now comes off easily you can get it to go on the windscreen but it takes 5 mins of messing about with it and the settings are Messed up. and body have any advice on how to fix it?
Old Aug 31, 2013 | 03:56 PM
'93, '94, '95, . . .
Is it automatic (ECC) or Manual (MCC)
Attached Thumbnails 850 t5 heater middle control knob not working-heat-ac-ecc-panel.jpg   850 t5 heater middle control knob not working-heat-ac-mcc-panel.jpg
Old Sep 1, 2013 | 05:22 AM
john12345's Avatar
Unhappy
its manual without air con. i took it apart yesterday and moved one of the cable that goes to the middle control so it blows on the windscreen again but the other cable which i think lets you put the heaters on the foot well seems to be stuck i have broke the little white plastic stick that the centre k n ob sits on so i could only adjust it by moving the cable. can the middle control be replaced or will i need a full unit?
Old Sep 1, 2013 | 08:09 AM
I haven't had a manual Volvo control apart but I'm guessing you'll need a complete head. I haven't seen any that are modular on other cars and from the photos of a MCC I don't think Volvo's is either.
Maybe someone else will jump in with an idea
rspi
May 15, 2014 07:36 AM
tjc61
Apr 19, 2013 02:18 AM
prdkld99
Jan 4, 2011 02:52 PM
Regis W
Oct 20, 2010 11:36 PM
nationm
Feb 12, 2006 10:09 PM
