850-T5 SMOKING WHEN IDLE
Old Jun 22, 2008 | 04:34 PM
andysvolvo's Avatar
Default 850-T5 SMOKING WHEN IDLE
hello to everyone,
i have two problems causing me great concern,the first is on my t5 when the engine is left to idle for longer than usual and then pull away a cloud of smoke can be seen from the exhaust pipe. this doesnt happen everytime some days it won't do it at all.
i seem to spend more time looking in my rear view mirror than the wind shield lately as i'm getting very aware of it,but the annoying thing is i never know when it's going to produce this big cloud of smoke.
and the other thing is a tapping comming from top of engine more noticable at idle speed i've changed the oil twice and filter in the space of four weeks but the tapping persists.
any help on these problems welcomed.
andysvolvo
Old Jun 22, 2008 | 04:40 PM
Default RE: 850-T5 SMOKING WHEN IDLE
1.Check the vent system really good is something is clogged it will make it smoke like that.
2.Maybe the oil pan o-rings are bad causing the tapping noise.
Old Jun 23, 2008 | 05:04 AM
BigAdam's Avatar
Not sure but I would say worn piston rings. Smoking goes away when revving, this is pretty typical.
Old Jun 23, 2008 | 08:35 AM
Psaboic's Avatar
Try the easy stuff first. Check the vent system for a clog.Then I would flush the engine and put in fresh oil and filter (might have a slightly sticking ring). Let us know how it goes.
Glenn
Old Jun 23, 2008 | 05:20 PM
andysvolvo's Avatar
hi, and thanks for the replies, i'll check breathers etcregarding the smoke fault i have, is it possible the turbo faulty? i have to stress the smoke problem isn't always there and i never know when it's going to happen.
there seems to be a trend looking at related threads they all seem to smoke more at idle.
could this be the engine is allowed to get hotter than usual before the fan cut's in? i can idle at traffic lights for say 2 minutes and when i move away no smoke is seen.
but i wager if it was more than that it would smoke.
as far as the engine tapping i noted that when started from cold no tapping but after say a minute the tap starts, the tapping is comming from the same areaunder the rocker cover sugesting it's only one lifter with the fault. i'll keep all informed of any remedies, and any useful comments gratefuly recieved,
mp4805
Sep 4, 2011 08:21 AM
james_caza
Jan 17, 2010 06:53 PM
oldervolvo
Apr 22, 2009 08:19 PM
andysvolvo
Jun 27, 2008 07:27 PM
danny
Sep 19, 2005 01:53 AM
