850 tdi
Old Jan 28, 2022 | 04:29 PM
John Seaton's Avatar
Default 850 tdi
Hi, new to us, was ok now lost boost. Not turbo man, not sure where to start with these. any ideas? ta
Old Jan 30, 2022 | 11:40 AM
Boost is controlled the waste gate. check if the actuator rod is disconnected or stuck. there's also a boost control solenoid which actuates the rod that has some vacuum lines running into it. See if any of those have tears or fell off. Not sure if the tdi has the same set up as the T5 turbos but a clogged PCV can create positive crankcase pressure which can pop off the vaccuum lines.
mopar21440
Mar 12, 2013 09:41 PM
Marvin Lee
Feb 9, 2013 07:00 PM
dirty
Nov 16, 2008 08:52 AM
