850 timing gear positions???? help
Old Apr 11, 2008 | 05:42 AM
kidbart's Avatar
Default 850 timing gear positions???? help
hi, ANYBODY know this. I replaced the head on the 1995 850 turbo. drove , ran great , had oil leak, seal on camshaft at gear side, distributor cam. replaced seal, forgot where to bolt gear back on. i lined up the gears to the notches on the plastic cover. the gear closest to cabin did not move, crank did not move, only the cam when removing the 3 bolts that hold on gear. NOW QUESTION IS, what postitoin is the cam sopostobe in so that I can bolt gear on, while alining notche/blue marks in reference to plastic cover/notch.I need to know where the rotor is /needs to point. If i got the rotor direction, then, I can turn camshaft to match, then bolt gear w/notch to match cover. does this make sence...???? does to me,
IN OTHERWORDS, WHEN THE GEARS ARE BOTH POINTING TOWARDS NOTCHES ON PLASTIC TIMING COVER/TOP OF MOTOR AS PER THE BOOK. WHAT CYLN./ DIRECTION IS THE ROTOR POINTING????? (DISTRIBUTOR ROTOR) ANYHELP OUTTHERE.. sorry for the caps. email directly to joaca@sbcglobal.net first person to help/correct ans that I can use gets a 10$ paypal gift card? pizza, 6 pack.. thanks, j
Schaeffy
Jan 8, 2014 06:36 PM
carlheat
Oct 25, 2010 10:36 AM
J Telectro
Nov 12, 2009 03:19 PM
dror_idn
Oct 28, 2009 04:39 PM
kwang
Jul 28, 2006 08:19 PM
