850 Transmission blinking upshift light
Old May 4, 2010 | 05:24 PM
crchemguy's Avatar
Default 850 Transmission blinking upshift light
1997 Volvo 850 non turbo, auto transmission
Intermittently throws codes "197707 read codes at 341 and at 332" (from Volvo dealer shop).
Going over bump when not shifting seems to trigger codes and blinking light. Transmission wasn't shifting or anything, just going down the road.
Tranny doesn't make any noise, and shifts and performs normally using manual shift
What are chances that I have a TCM problem or wiring harness problem rather than the lockup solenoid problem (please confirm these codes are for the lock up solenoid)
Thanks in advance, crchemguy
Old May 4, 2010 | 08:38 PM
crchemguy's Avatar
Default Added note to 850 upshift blinking light
I noted an earlier post that said that putting the key in, shifting from Park to Low 10 times stopped the blinking....a reply said that doing the shifting probably didn't fix anything...that a switch was going bad. Any ideas as to which switch and where? Thanks again in advance
Old May 10, 2010 | 03:52 PM
Draculaakumajou's Avatar
I'm having the same problem wuth my 94 automatic non-turbo, just started this morning.. the manual just says contact dealer.. it's shifting OK and revving normally.
anyone have any insight?
EivlEvo
Oct 7, 2012 11:04 PM
Torchio
Feb 7, 2012 10:58 PM
GmacA3
Oct 10, 2009 02:20 PM
olddaddy
Jul 31, 2009 03:52 PM
30KS80
Apr 13, 2005 05:26 PM
