Vacuum Lines & Trans Upshift Problems
Old Oct 10, 2009 | 08:47 AM
GmacA3's Avatar
Default Vacuum Lines & Trans Upshift Problems
Recently had an oil change a quick lube place (1990 740 Turbo with automatic) and they really messed up the car. The car was stalling and check engine light was on after they changed the oil. Opened the hood and found the large hose from the mass air flow sensor to the turbo input was off and the vacuum line to the trans kick down valve near the trans dipstick was off. Reconnected everything to where I thought it should be, disconnected the battery to get rid of the check engine light on. The problem is that now the Transmission will not up shift normally and is delayed. In other words you have to run up the RPM's and then back off on the gas to get the transmission to up shift - not good. I think I still have a vacuum issue somewhere that is effecting the transmission up shifts.
Anyone have some thoughts on this, It would be greatly appreciated Additionally: Never let two 18 yr. old girls change the oil on your car!
UPDATE: Problem Solved: I found the transmission kick down cable (located by the throttle cable) was stretched out of position causing the trans to want to be in a lower gear all the time. Just wanted to pass this along in case someone else has the same problem as I had thought the problem was vacuum related. The quick lube team really made a big mess of what should have been a simple oil change
Old Oct 10, 2009 | 02:20 PM
GmacA3's Avatar
EivlEvo
Oct 7, 2012 11:04 PM
Torchio
Feb 7, 2012 10:58 PM
crchemguy
May 10, 2010 03:52 PM
olddaddy
Jul 31, 2009 03:52 PM
30KS80
Apr 13, 2005 05:26 PM
