850 turbo-acceleration problem
Old Nov 20, 2008 | 07:59 PM
alphaville's Avatar
Default 850 turbo-acceleration problem
Hello everyone,
I just bought a month ago stock 96 850 turbo with 130000 k.It runs great except when i accelerate hard ,the car stars to hesitate -jerk. It only happens under heavy boost when auto trans is forced to downshift. Anyone who knows what it could be?
Thank you.
Old Nov 21, 2008 | 07:27 AM
Default RE: 850 turbo-acceleration problem
Sounds like it is misfiring like it needs a tune up.
Old Nov 23, 2008 | 12:03 PM
alphaville's Avatar
Tech, thank you so much for your reply and advice. You were right, the car needed tune up. Yesterday, i changed spark plugs, cables, distributor cap and rotor. What a difference when i took it for a spin. Now it runs like a swiss watch. One more problem i discovered when took off the engine cover, top of the motor was all covered with engine oil. Looks like it's leaking from oil filler cap, at least that's what i think it is. Will get new one tommorrow. Thanks again for your help.
Old Nov 23, 2008 | 09:50 PM
Psaboic's Avatar
Usually a leak from the oil filler cap is the O-ring on the cap that is leaking. You can change that and the two o-rings on the dipstick and it should solve any oily engine issues
Old Nov 24, 2008 | 01:51 AM
JPN's Avatar
JPN
The fender & door side mouldings are actually made in Switzerland...[8D]
See my 1st & 2nd replies in the following thread for a complete tune-up +:
https://volvoforums.com/m_48928/tm.htm
As to the oil leak, it is a known chronic problem to the 850s. Follow Psaboic’s advice, and I would also consider investing in a complete PCV component replacement.
PCV kit:
http://www.fcpgroton.com/product-exe...category_id/64
Gaskets & O-rings:
http://www.fcpgroton.com/category-ex...37/by_year/46/
Note, that in order to replace the PCV components, the intake manifold would have to come off, which means you need a new manifold gasket.
I hope all goes well.
JPN
volvorecycle
Jul 22, 2015 07:44 PM
bostongrun
Sep 30, 2011 03:57 PM
mattwade
Apr 6, 2011 11:25 PM
demian5
Jun 18, 2010 03:34 PM
fredimac
Nov 21, 2008 09:09 PM
