850 turbo brake pads
Old Apr 26, 2009 | 08:02 PM
dlaxdal's Avatar
Default 850 turbo brake pads
What brand name do you recommend for average driving.
Old Apr 26, 2009 | 08:09 PM
I always use OEM!
Old Apr 26, 2009 | 08:17 PM
dlaxdal's Avatar
What do you mean by oem and what brand
Old Apr 26, 2009 | 08:27 PM
Volvo pads.
I hate aftermarket pads they usually always squeel which drives me nuts.
Old May 3, 2009 | 12:55 AM
dlaxdal's Avatar
Default finished brake job
Just installed rotors and pads on the front. Thanks for the help and information on board. Sounds like the struts need to be changed and upgraded by reading the posts on the board.
Old May 3, 2009 | 07:41 AM
JimKW's Avatar
Not a bad job is it? By the way just and fyi OEM means Original Equipment Manufacturer which means you get it from a dealership. Some places like fcpgroton do carry some OEM parts also.
Old May 3, 2009 | 02:16 PM
1996850turbo's Avatar
FYI,
I have tried about 5 different sets of pads and have the following suggestions.
Rear Disc Pads ALWAYS USE THE OEM PADS!!! ANYTHING ELSE SQUEALS! Also the "special shims from the dealer" will help IF the OEM pads squeal.
Front Pads Either OEM or Euro Ceramic Pads (Akebono) The Ceramic Pads have MUCH less dust and it is easier to get off my Columba's. Anything other than these pads and I got "School Bus" type squealing.
Always use OEM rotors. Brembo. The surface quality is MUCH better on them than any of the others and slotted or crossdrilled rotors tend to have a lot of vibration under braking.
Buy a tube of the "grease" from the dealer and apply liberally it will cut down on noise and IMHO helps pad life by allowing them to "return" better when your off the brakes.
Old May 3, 2009 | 02:18 PM
BTW,
Do NOT apply the grease to the rotor or pad, just the backs of the pads, the pistons and the "slide points".
I don't think I needed to say that but you never know!
Old May 4, 2009 | 10:46 AM
bestharry's Avatar
Glad that you explaind the greasing points..... :P
Old May 4, 2009 | 03:26 PM
dan2286's Avatar
Has anyone tried EBC greenstuff pads? I have heard very good results for them on other cars, but not Volvo.
Old May 4, 2009 | 06:55 PM
RUN from them!!!! I put them on my Yellow R and took them off the very next day. They didn't even have 100 miles on them. The squeeled like crazy!!
Old May 8, 2009 | 07:30 PM
jpnankervis's Avatar
I will tell you my story with the so famous AKEBONO CERAMIC BRAKE PADS. I had bought the front pair, and up to now they work great, no squealing at all. So about a month ago, I decided to change the rear pads, and took a chance on the AKEBONO again. After I myself saw how the replaced the brake pads, I took the car at night and got to a bend, stopped at the enter of the curve and what do you know, the rear wheels locked, the car went straight forward and I crushed against a wall. The car took a hit in the corner light as well as the front bumper. So It spent about 3 weeks in the shop, and I took responsibility on the crash, until 3 days ago when I took it out of the shop, I realized that whenever I brake hard the rear wheels lock, when before with the oem brake pads I never had that problem, the car was so stable I enjoyed driving it hard. My suggestion, dont get akebono rear brake pads.
Johnny Volvo
Jul 12, 2011 11:52 PM
fortmemphis
Sep 20, 2010 08:56 PM
JetCity
Apr 17, 2009 06:32 PM
MattS77
Dec 19, 2007 10:31 AM
thullz
Nov 7, 2006 09:25 AM
