850 Wiring issues
Old Oct 28, 2015 | 02:27 PM
NealR's Avatar
Default 850 Wiring issues
Hi folks,
I'm the new owner of a '95 850 Wagon. Among some other issues that this beast came with is a set of weird wiring issues.
To start, the brake switch is fine
Right now, if the headlights are on and you press the brake, the licence plate lights go out.
As well, the center brake light isn't working. Seems like it could be the wires through the hinge. Any other possibilities?
Thanks,
N
Old Oct 28, 2015 | 09:17 PM
a good resource is volvowiringdiagrams.com I think you're on the right path assuming there's a short or open in a cable or connector that is related to the circuits to the bulbs in question. Does it change if you pull out the bulbs for the brake lights? all the fuses good?
Old Oct 29, 2015 | 12:40 PM
firebirdparts's Avatar
If the center brake light can prevent your tag lights from working, then that tells you they are grounded together and this ground is disconnected. When you are not using the brakes, the tag light is still working because electricity can flow through the tag light, then backward through the center brake light to "escape", then forward through the side brake lights to ground. This does not cause the brake lights to light up because it's not enough power. I hope this makes sense. It's a very common problem with cars generally (not just Volvos). I did not bother to look at the diagram and verify how these are grounded.
skylonda
2001-2013 model year V70
Sep 10, 2015 11:00 AM
sdl92
Jun 22, 2013 07:19 PM
piv15
Jul 19, 2012 05:39 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
