850 won't restart once ho
Old Aug 29, 2024 | 08:16 PM
MURKSER's Avatar
Question 850 won't restart once ho
850 won't restart once hot, but restarts after cool down.
Old Aug 30, 2024 | 08:04 AM
I'd start by checking the fuel pump relay and the injector relay (its on the cowling ). If you find bypassing the fuel pump relay gets the car to start, then its time to replace the pump as well as the relay. (a worn pump will draw too much current which can overheat the relay)
Old Sep 1, 2024 | 11:26 AM
MURKSER's Avatar
It starts again once it has cooled down. I've read somewhere about a purge valve???
Old Sep 1, 2024 | 12:04 PM
Yes there is a purge valve that dumps fumes from the charcoal cannister back into the intake under certain conditions - during starting/idling the valve is closed. It's not your purge valve. \
If it won't start when hot - do you have fuel pressure? Spark? (fuel pump relays are a common problem - cracks form in solder joints on the circuit board, as current flows, the resistance in the crack creates heat and eventually current does not flow. Once the relay cools off - current flows and fuel pump runs)
They usually crack where the windings for the electromagnet are soldered to the board - It takes a magnifying glass to see them.
Old Oct 30, 2024 | 12:37 AM
MURKSER's Avatar
The culprit was the cam position sensor.
pmb
Sep 13, 2006 12:15 AM
banj
Jan 12, 2006 10:59 AM
mz1214u
Oct 17, 2005 06:13 AM
BERNIE
Aug 15, 2005 06:01 PM
JimKW
Apr 9, 2005 11:59 AM
