96 850 glt won't start
Old Jan 10, 2006 | 11:17 AM
banj's Avatar
Default 96 850 glt won't start
It's been sitting for about 8 months. Batteries good but it won't crank.
Old Jan 10, 2006 | 11:17 PM
Default RE: 96 850 glt won't start
It won't crank or it cranks but won't start?
Old Jan 11, 2006 | 02:49 PM
banj's Avatar
It won't crank. When I turn the key nothing happens. (other than headlights turning on etc...)
Old Jan 11, 2006 | 05:33 PM
B1mmer's Avatar
You're sure your battery is putting out a good 12V? The lights may come on, but it probably doesn't have enough juice to move the starter. Also, check to make sure the car is in park. Turn the ignition to on, put the car in drive, then back to park. - AB
Old Jan 11, 2006 | 11:28 PM
If you can't get it to crank. Find the small wire at the starter and check for power with the key in the start position.
If you have power and nothing happens the starter is bad.
Old Jan 12, 2006 | 10:59 AM
banj's Avatar
The battery is good. It came straight from my v70. I also tried jump starting it and had the same problem.
I'll check the wire going into the starter.
Rural Juror
Nov 16, 2013 08:35 PM
WNCMAN
Mar 30, 2010 10:02 PM
RickF
Nov 24, 2008 01:23 PM
JKinPA
Nov 14, 2008 08:40 AM
melmel7103
Mar 30, 2008 10:36 PM
