850GLT NO HOT AIR
Old Feb 21, 2008 | 09:47 PM
CHENSC850GLT's Avatar
Default 850GLT NO HOT AIR
my 1993 850GLT suddently has lost the hot air capability. Fan still run A/C (cooling) is ok when turn on but no hot air in winter time. Is somthing wrong with the Environmental Control Unit ? Also, I can only control driver side A/C not the passenger side. Anyone can help ?Thanks.
Old Feb 21, 2008 | 10:17 PM
RedTurbo850's Avatar
Default RE: 850GLT NO HOT AIR
How's the thermostat working? Is that needle functioning correctly?
Old Feb 21, 2008 | 11:37 PM
JPN's Avatar
JPN
It is called Global Cooling[8D].
Yes most likely the thermostat has retired if you lost heat. As to the pax-side control not working, one of the damper motors may have retired or is out of calibration.
Pull codes & see what you find, then reset the system to see if the same code comes back.
JPN
[IMG]local://upfiles/6892/201A59266BAD49349C624E2A46C4B5AE.jpg[/IMG]
[IMG]local://upfiles/6892/FB916C32EAF54610BEE36AB05C4F3A8F.jpg[/IMG]
[IMG]local://upfiles/6892/ED679746EF2A4900B5271DC6E240CEF5.jpg[/IMG]
[IMG]local://upfiles/6892/1CF6D36FE8CF450AACD647B3AF5816F0.jpg[/IMG]
[IMG]local://upfiles/6892/D5BAFCD4EF0B4316A7D06FF60C868A02.jpg[/IMG]
Old Feb 21, 2008 | 11:47 PM
Maxbaby's Avatar
You have a 1993 so you can read codes under the hood. Read B1 and see what comes back. Chancesare it's your thermostat though.
elbert
Oct 18, 2011 10:54 AM
somethingsalty
Oct 10, 2009 05:57 PM
austeve
Jul 29, 2008 09:08 PM
beardo265
Sep 27, 2007 09:24 AM
