Odometer fix nightmare
Old Feb 20, 2008 | 05:36 PM
pmpalma's Avatar
Default Odometer fix nightmare
Gents,
I've succesfully repaired the infamous odometer gear fix. Unfortunetly managed to screw up many things...
among burning close to all my lights, I've also manage to brake my gas gauge, so I think.
All worked fine before the odometer thing, don't have a clue on why all my light burned nor why did my gauge died.
Did the A7 cluster check thinggy, needle dosen't move.Did the A7 cluster check thinggy, needle dosen't move.
Got an used cluster form the salvage yard, swapped the cluster, still non working gauge. I realize that gauge might be faulty, but what are the chances of that happening?
Did the A7 cluster check on the "new" cluster, still no movement.
Could it be possible that I've yanked a a wire that powers that gauge? Faulty realy sowhere? It's doutful that the sending unit is faulty, since the cluster check is pointing to a faulty gauge... but two faulty gauges in two different units?
Thanks to all
Old Feb 20, 2008 | 06:28 PM
Default RE: Odometer fix nightmare
That would be very odd if it is true.
I would check the wiring.
Old Feb 20, 2008 | 08:52 PM
JPN's Avatar
JPN
Did you make sure that all electrical connectors were secure on the cluster assy?
JPN
Old Feb 22, 2008 | 08:26 AM
Psaboic's Avatar
Definitely check the connectors as well as stretched/pinched wires.
twiin64
Aug 4, 2012 11:17 AM
palirwin
Feb 25, 2012 06:10 AM
quarterdimenickel
Jul 16, 2008 07:52 AM
markymarc1981
Jan 10, 2008 10:54 PM
Volvorator
Mar 15, 2007 10:37 AM
