850R front bearings
Old Sep 22, 2009 | 02:36 PM
boldtu's Avatar
Default 850R front bearings
I recently bought a 97' 850R wagon with 140,000 miles. My buddies and I went to Vegas last weekend from Los Angeles and I started hearing some noise coming from the front left of the car. I got a small amount of vibration with some light grinding noise. I think it is the front bearings, does this sound right? Anyone know of a good place to get the rebuild kit?
Thanks,
Chet
Old Sep 22, 2009 | 07:07 PM
Sounds like it might be it.
Check out FCPgroton.com There is no rebuild kit you need to buy the assembly.
Old Sep 23, 2009 | 05:58 PM
boldtu's Avatar
Great! I found the hubs on the site you sugested.
If the bearing is the only thing that is worn, do I need the hardware kit or just the hub?
thanks
Old Sep 23, 2009 | 07:26 PM
You do not need the hardware kit. If it makes you feel safer put a few drops of loctite on the threads and install them.
Old Sep 23, 2009 | 11:19 PM
boldtu's Avatar
great, thank you
on FCGROTON.com they show an aftermarket hub. Would you recomend that or the OEM part?
Thanks again for all of your help
Chet
Old Sep 24, 2009 | 06:18 PM
I forget for sure if *** is OEM or not. But I use them all the time and they work Great!
rationull
Jan 25, 2022 03:12 PM
ThomBS40
Feb 6, 2014 06:56 AM
1BADV6
Jan 29, 2013 08:33 AM
Greener
Canada, Over Seas & Elsewhere
Dec 11, 2012 11:24 PM
brandons70
Feb 7, 2010 08:16 AM
