93 850 bogging issue
Old Aug 16, 2009 | 02:04 PM
tha legend713's Avatar
Default 93 850 bogging issue
I have a 93 volvo 850 and the car was running good with no problems and then all of a sudden the next day when I started to warm it up i noticed a little miss. well anyways I proceeded to take off and the car started hesitating really bad to the point that it turned off a couple of times. I changed the fuel filter and spark plugs you know the usual tune up, but the car is still bogging out real bad! almost gorgot to mention that the exhaust smells funky..maybe like its burning too rich? any ideas on what it could be?
Old Aug 16, 2009 | 02:30 PM
gilber33's Avatar
MAF maybe, does it idle rough?
Old Aug 16, 2009 | 07:01 PM
not too bad but not as smooth as it should be...
Old Aug 16, 2009 | 07:04 PM
gilber33's Avatar
start the car and then unplug the MAF and see if the idling changes much. Or try cleaning it with MAF sensor cleaner
Old Aug 17, 2009 | 10:22 AM
fcpgroton's Avatar
Former Sponsor
Could also be the fuel pressure regulator. If the MAF cleaning does not fix it, I would look at that next.
Old Aug 17, 2009 | 04:39 PM
sauer9's Avatar
no codes showing up?
Old Aug 24, 2009 | 03:16 PM
ive tried mostly everything...BUT last night when I had the motor running I grabbed the spark plug wire and it shocked me!! so I looked into it and noticed a small crack in the wire and spark coming through??...could that be my problem???
nuclearseal
Dec 11, 2012 08:01 PM
Green 850 GLT
Aug 6, 2012 03:37 PM
Rosew6211
Nov 21, 2010 09:59 AM
thecarfarm
Apr 15, 2007 02:07 AM
robohopar
Jan 11, 2005 05:32 PM
