93 850 corner light assy replacement
Old Mar 17, 2013 | 11:35 AM
hearno's Avatar
Default 93 850 corner light assy replacement
Just picked up a 93 850 and both corner light assemblies are missing. I have the parts on order and while searching thisforum for instructions - found that there is some sort of spring that holds them in place as opposed to clips or screws etc. Can anyone give me a rundown on what is actually needed? I'm guessing the lamps I got on ebay won't come with the springs which are probably missing and why the original lamps fell out in the first place.
Old Mar 17, 2013 | 01:55 PM
To install or remove you need a 6" or longer screwdriver and you reach down from inside the engine bay and engage a loop about the size of your finger and pull the spring out of a "V" groove.
The lamp has locating pins that will seat into holes to locate it and then the springs tension holds them in place.
P/n at IPD 114377 - turn signal retaining spring 850 $3.24
Trying to find a photo of the spring installed.
Attached Thumbnails 93 850 corner light assy replacement-turn-signal-front-retainer-spring.jpg
Old Mar 17, 2013 | 02:32 PM
MattyXXL's Avatar
You should have bought the euro corners from FCP..
The ones for 93's are the only one they have left..
Dual bulb, nice look and a hell of a lot cheaper.
Old Mar 17, 2013 | 11:06 PM
hearno's Avatar
Perfect, thanks.
You are correct... I wish I had posted first. I only spent $50 so it was close but I might return them and go to FCP.
Thanks for the replies gents.
turbo-max
Nov 12, 2014 07:36 PM
Bishop1782
Sep 21, 2012 09:59 AM
pretnear21
Mar 29, 2011 10:29 AM
dgm76513
Oct 11, 2008 08:47 AM
deanj
Oct 14, 2005 03:31 PM
