94 turbo wagon hard miss when warm
Old Jul 12, 2014 | 12:08 PM
sparkmaster1's Avatar
Default 94 turbo wagon hard miss when warm
Driving my 850 when the temp gauge gets to the middle (warm ) it will get a hard miss about every 10 seconds, like the key is turned off/on very quickly. the tach also takes a quick dip, and never has thrown a code. . The only codes I have gotten in the past is knock sensor,, and Cat efficiency. It has about 240 K on it and otherwise runs very well, Did a full tune about 15k ago with all good parts from IPD. Swapped fuel relays. cleaned MAF, checked cap/rotor,.. When it's cool out it does not do it.. it's about 80-90 outside here now. Could the Cat be the problem? Did a search and didn't find anything.
Thanks, Tim
Old Jul 12, 2014 | 04:53 PM
Just got back from hot drive, Cat reads 462 at front, 320 at back.. Bad Cat??
Old Jul 13, 2014 | 12:21 PM
firebirdparts's Avatar
If the tach drops to zero, I think it's the crank sensor. Magnets are affected by temperature.
The program in the ECM could have lots of features that I don't know about, but I would not think a quick misfire performed deliberately by the ECM would help the catalytic converter. It's not something that would be related by natural causes, for sure. The lack of reaction efficiency in the cat doesn't affect anything except emissions and that is detected by the rear O2 sensor.
Old Jul 13, 2014 | 09:49 PM
That's a good call, I'll get one ordered up and replace, Thanks,
Old Jul 17, 2014 | 04:19 PM
Replaced the cat,, and crank sensor, no problem yet, Did notice the connection blocks on crank and cam sensor very corroded, green.. cleaned both and put back on with dielectic grease.
Tim
Squirt
Dec 29, 2020 02:53 PM
DecalService
Dec 4, 2019 10:52 PM
jmoney2001
Feb 18, 2011 08:16 PM
furball3
Jan 28, 2007 03:31 AM
Sapient
Apr 10, 2006 10:40 PM
