'95 850-abs idiot light-car wont start
Old Jul 8, 2007 | 09:34 PM
ontopcop's Avatar
Default '95 850-abs idiot light-car wont start
We have a 95 850 sedan. From time to time, after starting the car, the ABS light comes on and the car will not shift into gear, then, if we jiggle the key, the light will go off and the car will then go into gear. Does the ABS need to be reset? Any suggestions or ideas. Thanks
Lanny
Old Jul 8, 2007 | 11:40 PM
JPN's Avatar
JPN
Default RE: '95 850-abs idiot light-car wont start
Hello Lanny,
I distantly remember that a faulty ignition switch could cause this problem on '95 or earlier 850s. Generally, not being able to shift is due to a faulty PNP switch or a micro switch, but in your case it may be the ignition switch, considering the correlation with ABS warning turning on & problem disappearing when you wiggle the ignition switch.
Getting codes & reseting the ABS module is definitely a plus, and since your 850 is '95, you can reset it by yourself without any testers/tools. However, I assume the problem would persist even after resetting the ABS module, so I would look into the ignition switch. My ignition switch used to come out of its nest and there were no screws or other fasteners for it.
I believe someone in this forum may have had a similar problem so wait till they reply if you can. If it turns out that the ignition switch is at fault, you can get a new OEM switch at FCP Groton for $51 + shipping.
http://www.fcpgroton.com/volvo850other.htm
I hope this gives you some hints as to the problem.
JPN
Old Jul 9, 2007 | 12:21 AM
ontopcop's Avatar
JPN,
Thanks, that is actually decent news. It's never not started, so that is a good thing. I will look into that ignition switch in the mean time. And I look forward to hearing how I can reset that ABS manually.
Old Jul 9, 2007 | 01:01 AM
JPN's Avatar
JPN
Hello again,
This URL link explains how to reset the ABS module:
http://volvospeed.com/Repair/a3.html
(Courtesy of Volvospeed.com)
I hope this helps.
JPN
suze
Jan 30, 2014 07:42 AM
daver80
Jul 21, 2009 11:46 AM
S70driver
May 25, 2006 01:00 AM
Bummer
Jun 3, 2005 02:26 PM
