No Blinkers but fuse and flasher seem to be OK
Old Jan 21, 2011 | 06:27 PM
mountainluv's Avatar
Default No Blinkers but fuse and flasher seem to be OK
1995 960. The blinkers will work some times but most of the time they do not work at all. When the blinkers are not working the hazards work just fine. I have been told that there is only one flasher unit that controls both the blinkers and the hazards, so I ruled out the flasher. I checked the fuse (#19) it is just fine. I took the switch off the steering column and figured out which circuit controls the blinkers by taking apart the switch itself. I then tried a direct wire to complete the circuit and still have no blinkers. I will assume the switch is good too since some times the blinkers work. Any thoughts on a next step.
Thanks
Old Jan 23, 2011 | 09:21 PM
Replace the front turn signal bulbs.
RyanA
2001-2013 model year V70
12
May 2, 2014 05:37 PM
honeyfixthecar
Jun 8, 2009 01:23 PM
honeyfixthecar
Jun 5, 2009 03:29 PM
volvodrummer
Jan 5, 2007 06:20 PM
