95 850, no signal to injectors HELP!
Old Sep 12, 2012 | 11:45 AM
rms1's Avatar
Default 95 850, no signal to injectors HELP!
I have a 1995 850, non turbo, automatic. We just replaced the engine with a junkyard one, new cap, rotor, plugs, wires, coil, FP relay, cam and crank sensors. I've double checked all connections. With a noid light im getting no signal to the injectors. The main relay "buzzes" with the key on. When I check the green wire with my test light the buzzing goes away. Good fuel pressure, runs off either but won't run on it's own. Car ran when it came in but had a bad rod knock so we replaced the engine.
Vmax
Apr 7, 2014 07:42 PM
jea
Sep 11, 2012 12:15 AM
scottvickers
Oct 26, 2011 04:36 PM
B00$T CR33P
Jul 8, 2010 04:04 PM
eboknight
Mar 22, 2009 10:30 PM
