95 850 Removing Steering Wheel
Old Jul 10, 2007 | 10:20 AM
Eli Delta's Avatar
Default 95 850 Removing Steering Wheel
any one have any advice on freeing a steering wheel on a 95 850 for the ac evaporator R and R.
Old Jul 10, 2007 | 01:02 PM
Eli Delta's Avatar
Default RE: 95 850 Removing Steering Wheel
am I going to have to get a gear puller to get this steering wheel off. The nut will not brake loose.
Old Jul 11, 2007 | 02:33 AM
JPN's Avatar
JPN
Hello Eli,
I myself never had to take the steering wheel off, and I no longer have 850 with me so my info may not be accurate.
Is the holding nut still there? If so, I would use the correct size 6-point socket with a breaker bar. Be sure to follow safety precautions on the SRS; disconnect the negative battery cable and follow up with any additional precautions.
If all fasteners are off and the wheel still wants to stay in its nest, you could try spraying a bit of PB Blaster and keep wiggling as you pull on the wheel. Or you may want to tap it from the back side of the wheel with plastic hammer.
Do all tasks at your own risk, and be sure to follow the safety precautionsfor SRS.
Good luck,
JPN
puxnstx
Dec 13, 2014 11:36 AM
trainlover
Mar 16, 2014 08:48 AM
wallst32
Aug 29, 2011 07:30 PM
nehopsa
Jun 24, 2008 11:20 AM
