95 850 Turbo need help with wiring
Old Jul 15, 2021 | 03:13 PM
dextro's Avatar
Default 95 850 Turbo need help with wiring
So I had issue with car stalling replaced MAF sensor and Fuel Pump Relay and seems like it fixed the issues, but check engine still shows "System Too Lean 1". Ordered Fuel Injectotion Relay. It will arrive on Monday.
And I noticed few wires/hoses disconnected near battery and front driver's side headlights. Any ideas what are those?
Old Jul 16, 2021 | 10:09 AM
Headlamp wipers or adjustable beam headlamps, in other markets.
system too lean may be an air leak - check the small rubber connection to the intake manifold hidden by the power steering pump (if equipped)
Old Jul 16, 2021 | 10:25 AM
air leaks - also check the vacuum tree under the throttle spool cover. there's a few branches that should be capped, and make sure the lines are not cracked
atsharp
Jun 3, 2016 03:52 PM
DuramaxSilvy
Nov 14, 2012 07:44 PM
bob330
Jul 15, 2011 08:12 PM
jamie
Jul 1, 2008 10:34 AM
pierre
Jan 22, 2008 06:24 PM
