850 dies randomly? please help
Old Jun 30, 2008 | 02:39 PM
jamie's Avatar
Default 850 dies randomly? please help
my 850 drives great but sometimes dies randomly, replaced fuel filter , spark plugs an everything r fine. ne ideas?
Old Jun 30, 2008 | 03:54 PM
Ozark Lee's Avatar
Default RE: 850 dies randomly? please help
What year is the car? Turbo or non turbo? Is your check engine light on?
The runs fine and then suddenly dies for no apparant reason is often due to a fuel pump relay starting to go bad.
...Lee
Old Jun 30, 2008 | 04:19 PM
axelm's Avatar
Could be a bad camshaft sensor.
How does the car respond when you floor it? Fuel pump could be reaching its funeral...
Old Jul 1, 2008 | 08:47 AM
Psaboic's Avatar
Outside of taking a SWAG (Scientific Wild *** Guess) we need to get more info.
Old Jul 1, 2008 | 10:34 AM
Quick Brick's Avatar
I like that, SWAG [sm=smiley36.gif].
How long has this been going on for. Also, add the above asked questions as more information is required before the forum can help you out. Share with us, we sharewith you.
I thought that it might have been poor fuel, in the beginning, but has persisted for some time?
Have you been able to pull the codes? 1992 -95 have a duel port setup under the hood. 1996 and up have an OBD2 port located under the coin tray in front of the shifter. There are two torx small screws to remove the tray and the connector should be directly underneath.
Give more info and get more help [sm=smiley20.gif].We are here for you and your Brick [sm=icon_rock.gif].
[sm=icon_cheers.gif]
[IMG]local://upfiles/14053/D449D24E0BD34C16A62F55381E6E7D2F.jpg[/IMG]
jayson44
Apr 11, 2013 01:52 PM
pdunn
Jan 24, 2012 07:56 AM
oct6454
Dec 25, 2011 08:15 PM
dieselsnowmobile
Nov 7, 2011 07:32 AM
Sean in Austin
Feb 20, 2007 11:14 PM
