95 850 wont start
Old May 29, 2010 | 01:12 PM
burple850's Avatar
Default 95 850 wont start
Hey I'm neorkw to volvo but I do work on cars. I got this volvo 4 days ago it ran good the first few days it just hesitated a little to start up. Now I pulled into a gas station and went to start the car again and it took a good 5 min to start then later at a friends house it wouldn't start at all... the next morning I tried to start it and it fired up within 10 seconds... I replaced the fuel filter and plug wires. And its getting spark. I tried to test the fuel with the valve on the end of the fuel rail and uts onlg dribbling gas out what should I do? The car won't start at all now and idk what to do! Any suggestions?
Old May 30, 2010 | 07:36 AM
VTBricked's Avatar
If the fuel just dribbles out at the fuel rail, check the fuel pump pressure. Your symptoms seem like failing fuel pump, too, but be sure before you buy a replacement pump.
Old May 30, 2010 | 10:16 AM
stojakovic's Avatar
You can try putting seafoam in gas tank.
Old May 30, 2010 | 11:07 PM
boxpin's Avatar
+1
Agreed, you will need to find out what your rail pressure is or if it is even getting fuel. Sounds like it is not.
Old Jun 3, 2010 | 06:45 AM
1996850turbo's Avatar
Fuel Pump Relay?
suze
Jan 30, 2014 07:42 AM
Fern Schmidt
2001-2013 model year V70
Aug 13, 2013 06:43 PM
waltonsauto
Feb 1, 2012 10:31 AM
alex57
Sep 28, 2010 06:48 PM
furball3
Jan 28, 2007 03:31 AM
