'96 850 GLT Debauchery
Old Dec 27, 2015 | 07:32 PM
Jogger's Avatar
Default '96 850 GLT Debauchery
Just acquired a 1996 850GLT US version.
While trying to repair the ABS I have made the following discovery.
It seems the previous owner had the front left steering knuckle replaced with the wrong part.
The car came to me with what looks like the WSS from a s70 or the like spliced in.
Closer examination reveals that the mounting hole is smaller in the knuckle and won't accept the OEM 850 Wheel Speed Sensor.
The installed sensor is a 2wire Active Wheel Speed sensor so it doesn't work.
Anyone know if there is a smaller diameter passive wheel speed sensor that will fit in this wrong knuckle?
Thanks in advance
Old Dec 28, 2015 | 07:16 AM
Psaboic's Avatar
No, I do not know of an alternate part. I would suggest that you get the correct steering knuckle and WSS. It will most likely be simpler in the long run!
Old Jan 4, 2016 | 08:42 PM
Probably a $12 junk yard part.
Old Jan 20, 2016 | 11:05 PM
I'm with him Get the right parts as it's steering AND brakes !!
Old Jan 20, 2016 | 11:29 PM
Jogger's Avatar
Done deal.
Used part came with ABS sensor . Installed and working.
Just had to tweak the wheel alignment and install wiring harness repair kit back to fusebox.
Old Jan 21, 2016 | 12:13 AM
Life is good.
Now hopefully you have working ABS.
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
Jogger
Dec 27, 2015 02:10 PM
gentlejax2
Apr 15, 2011 10:21 AM
squiz
May 12, 2010 03:27 PM
VolvoSwede
Aug 9, 2009 08:12 PM
