96 850 suspention
Old Nov 18, 2007 | 12:00 AM
dsniner's Avatar
Default 96 850 suspention
hello. i just got a 96 850 wagon with 86k on it. the suspention nearly gone. any suguestion on a shock and strut combo that will give it a smooth ride. i am looking for comfort over performance, as well as the best price. this sight has a few options listed but i was wondering what the volvo community has to say. also are the endlink bushings replaceable or should i get the ebay 30 dollar kit. also what other bushings should i look at besides the sway bar.
thanks dave
Old Nov 18, 2007 | 07:39 AM
jks2's Avatar
Default RE: 96 850 suspention
If you are looking for comfort I would go with OEM parts. Upgrading to Koni's etc. would just be a waste of money.
Old Nov 18, 2007 | 11:08 AM
info2x's Avatar
OEM (sachs) is a good bet and they do provide for some spirited driving as well. Just buy new endlinks, new parts make the world go round.
www.fcpgroton.com for parts.
Old Nov 18, 2007 | 11:16 AM
S70driver's Avatar
OEM or Bilstein TC's.
Old Nov 18, 2007 | 01:37 PM
dsniner's Avatar
is this ebay auction a good deal. do i need new strut mounts
http://cgi.ebay.com/ebaymotors/VOLVO...ayphotohosting
Old Nov 18, 2007 | 01:48 PM
S70driver's Avatar
Its ok. Can you install yourself?
Old Nov 18, 2007 | 01:51 PM
dsniner's Avatar
i can do the install, but what do you think of the price and do i need the strut mounts or can i reuse the old ones. is that a wear part. my subaru had bearings in the upper mount but they were fine.
Old Nov 18, 2007 | 02:00 PM
tripleb's Avatar
If you pry up on the upper big washer and look under it at the upper strut plate you will see the condition of the strut plates and be able to determine if they need replacement.
If they have any substantial cracking, I would replace.
Also make sure the motor mounts are ok, they tend to collapse and when you hit a bump, the engine can hit the subframe bumb stops and it will give you a pretty rough ride.
B
Old Nov 18, 2007 | 03:34 PM
RedTurbo850's Avatar
I would replace the springs seats and shock mounts while you're at it. They tend to go bad very easily.
Also, replace your endlinks (front) with HD enlinks. Those also tend to go bad. The strut mount (piece of metal) I wouldn't spend money on. It's a piece of metal and thus it seems like it'd be hard to fail.
Edit: I just saw your Ebay link. I would not buy that kit.
I was doing a lot of suspension reading earlier because I'm clunking relaly bad (just bought HD spring seats (front), HD shock mounts (rear) and HD adjustable endlinks). I looked at FCP's package, and I know that the spring seats and endlinks they give you are cheap aftermarket parts. For those parts that like to fail, I would definetely get the OEM ones. I got my set of OEM HD spring seats/shocks mounts from Ebay. I talked to the guy and apparently they are made by Hamburg-Technic which is a pretty reputable/solid brand.
Old Nov 20, 2007 | 03:12 AM
JPN's Avatar
JPN
Default RE: 96 850 suspension
I would replace all hardware except the cross-shaped nuts.
Copy & Paste from: https://volvoforums.com/m_48928/tm.htm
FRONT SUSPENSION:
1. Upper mount (bearing) with new nuts x 3 each side (total of 6 nuts).
2. Upper springseat (notorious for wearing out & causing clunking noise).
3. Bump stop for strut
4. Special washer for strut
5. Top cap for strut
6. New bolts & nuts for strut lower attachment.
7. Ball joint/control arm with new nuts & bolts (Newer models cannot replace ball joint alone).
8. Sway bar (stabilizer) link rods (new parts should come with new lock nuts).
9. Struts (only if the car rolls too much or the car keeps bouncing after hitting bumps). Either OEM Sachs or Bilstein Touring is good. Bilstein Heavy Duty seems to be a bit too firm. Koni Adjustable seems to have good reputation too, as you can adjust the damper.
REAR SUSPENSION:
1. Shocks (Sachs, Bilstein Touring or Koni Adjustable)
2. Upper shock mounts
3. New lock nuts
http://www.fcpgroton.com/volvo850shocks.htm
http://www.eeuroparts.com/home.aspx
The OEM struts (Sachs) are $95 each.
The OEM shocks are $55 each.
You may not have to do the ball joints, unless there's a play or the dust boot is undeniably ruptured.
I hope this is of some use. Should you decide to do the job on your own, make sure to follow safety precautions for compressing the coil springs. If you have doubts, let pros do it for you.
JPN
Old Nov 22, 2007 | 12:50 PM
dsniner's Avatar
thanks for the info. do you think that the Bilstein touring is better than oem. i am looking for comfort and the price difference is minimal.
Old Nov 22, 2007 | 05:48 PM
JPN's Avatar
JPN
I believe the Bilsteins are a bit firmer than the OEM Sachs. Also, since the 850s were designed as sport sedans/wagons, the ride tends to get on the firmer side. The tyres also haveshorter side walls, which makes the ride firmer too.
If you want comfort, I would go with the OEM. I used Bilstein Touring and was very happy with them, but they may be a bit firm if you seek comfort.
Whichever you decide to buy, make sure to replace the all hardware (except the rubber dust boots and the cross-shaped nuts). You don't want to go back there just to replace a special washer.
I'll let others give you different perspective.
JPN
Old Nov 23, 2007 | 03:36 PM
Suspension work sucks. Especially in MN where you got so much rust.
dsniner
Feb 14, 2008 07:58 AM
dsniner
Jan 23, 2008 06:52 PM
cbevis
Suspension
20
Oct 15, 2007 08:50 AM
zerocover
Jun 1, 2007 11:19 AM
OverTheTop
Suspension
Aug 22, 2006 10:06 PM
