96 854 T5 - Combustion smells way too rich
Old Mar 19, 2006 | 09:39 AM
axelm's Avatar
Default 96 854 T5 - Combustion smells way too rich
After driving for a while, when I reach home and park my car, my wife always complains that the car´s emissions have a strong gasoline smell.
My father in law drove the car while I was away travelling on business and he told me he thinks the fuel-air mix ratio must be off.
My car has the lambda (emissions) light on, and the EVAP valve will be changed in a couple of weeks (waiting for the darn spare). Could this be causing the problem?
It could be the O2 sensors too, I don't think they have ever been changed since the previous owner did not have the work "maintenance" in his dictionary.
Old Mar 19, 2006 | 09:31 PM
Default RE: 96 854 T5 - Combustion smells way too rich
Is the check engine light on?
Do you have the codes if so?
Are you leaking any gas at all after fill up?
Old Mar 20, 2006 | 08:17 AM
axelm's Avatar
Lambda light is on, CEL is off.
I don't have the codes, but Volvo told me the EVAP valve has to be changed.
It happens at any time, not only after filling up.
Old Mar 20, 2006 | 08:44 PM
The Evap Valve could be stuck open and causing the Gas smell.
It could also be a cracked rubber line by the Fuel Tank.
Old Mar 21, 2006 | 07:08 AM
axelm's Avatar
If it were a cracked rubber line by the tank wouldn´t I smell it when I fill up?
Right now I only smell it when the engine is running. Fill ups are fine...
Old Mar 21, 2006 | 08:54 PM
Possibly. Also check ther small hose that runs from the Radiator area to the Rear of the car.
There is a valve next to the cooling fan. The hose runs to the back of the car check that. When the car runs that is for the self test to see if the tank system has a leak. Gas fumes will come out when the car is running and the Valve is working.
Also look on the engine and find the injectors. On the left side of the fuel rail see if you have a return line.If you do there will be 2 lines from the fuel rail. Check the return line for cracks.
zSwede
Jul 30, 2015 09:33 AM
joshofalltrades
May 26, 2013 01:07 AM
alienek
Sep 23, 2012 04:17 AM
cm123
May 18, 2009 10:11 PM
junkmorning
Mar 23, 2005 10:51 PM
