96 Volvo 850 wagon turbo jolt going into reverse?
Old Dec 15, 2010 | 09:35 AM
boostnm3's Avatar
Default 96 Volvo 850 wagon turbo jolt going into reverse?
Was wondering if this is a sign of the tranny going out? When you stick it in reverse, the car makes a thump. Only into reverse. Im thinking of buying the car but didnt know if this would be a problem. Guy says its always done it since he had it. car has 160k miles. What do you think
Old Dec 15, 2010 | 10:42 AM
ibified's Avatar
I'd suspect the transmission mount or one of the other motor mounts first. If you havent replaced the top mount or the transmission mount, I'd start there. I had a similar issue and replaced the transmission mount busing with the IPD polyurethane one and have had no issues since then.
Firewall bushing:
http://www.ipdusa.com/Volvo-850/Engi...-153-249-6263/
Top Stabilizer mount:
http://www.ipdusa.com/Volvo-850/Engi...-153-249-4620/
Transmission mount bushing:
http://www.ipdusa.com/Volvo-850/Engi...-153-249-3326/
For the transmission mount, I went with the blue bushing, and just pressed the old one out and put the new one in. If you feel the need to replace the whole thing, it should take you less than half an hour to swap it out for the whole assembly.
Old Dec 16, 2010 | 09:47 AM
boostnm3's Avatar
thanks for the information. the car has 162k miles and he says it runs great. already has boost gauge, 15 lbs, downpipe, exhaust on it.
Syrussingh850r
Mar 7, 2015 01:59 PM
lukaspanic
Mar 17, 2011 12:32 AM
Mike Hasson
Jul 20, 2009 09:14 AM
Baldrick
Sep 27, 2007 02:50 PM
Dainos
Jul 15, 2007 04:03 PM
