97 850 AUTO CLIMATE CONTROL ISSUE
I have the a/c & rec lights flashing, I have removed the glove box and dash so i can see the rec. damper motor (moves postions when switched to rec,) and the defrost/floor motor. The local dealer ran codes and advised i needed to replace all the motors, but when i plug any of the motors into the rec. damper moter wire harness they move and index fine. The blower moter and slide switch work, the temp dials work, but none of the dampers motors work in rec mode or freash air mode except for thr rec. damper, any advise?
Hokiefanatic93
Aug 5, 2011 09:04 AM
Hokiefanatic93
Aug 5, 2011 09:03 AM
bond007
Jan 27, 2011 03:49 PM
