97 850R wagon suspension setup in Los Angeles
Old Aug 26, 2013 | 06:30 PM
manoduv's Avatar
Default 97 850R wagon suspension setup in Los Angeles
So I'm overhauling my suspension; original goal was to get as close as possible to original OEM setup, but I've since leaned towards the following:
Bilstein TCs at all four corners
Lesjofors front coil springs
IPD overload rear springs (for loading the car with people for camping, as well as semi-frequent furniture hauling)
Meyle control arms and bushings
IPD sway bars
Now I'm asking you what you think; will the overload springs and Bilstein TCs be an okay combination in the rear? The roads in LA sometimes suck, so I want something comfortable but I'd also like to be able to carve out some mountain roads on the weekends. Would Sachs and 4 Lesjofors with the IPD sway bars be a better setup for this purpose?
Thanks for input, I looked all over but reviews of various setups vary.
Old Aug 26, 2013 | 11:53 PM
gdog's Avatar
I have Bilstein TCs and IPD sways on both my cars and can't rave enough about that setup; slightly firmer than stock dampening but very controlled and the sways will definitely entice you to do some corner carving.
Sorry can't help with the springs; mine are stock. And I don't recommend mixing brands/types of shocks between front and rear.
Old Aug 27, 2013 | 04:47 PM
manoduv's Avatar
I think I'm going to go with Eibach pro springs and oem Sachs, and skip the IPD sway bars, unless I feel I need them. Hopefully it won't be too harsh with my 205/45/17 tires.
endneu913
Apr 16, 2015 09:36 PM
sandiegan
Apr 23, 2013 01:13 PM
gedgengras
West
Jan 7, 2009 07:16 PM
rcanS40
Oct 16, 2007 03:32 PM
ponies
Sep 10, 2004 04:55 AM
