Aaron's 1994 T5 sedan thread
#21
Well, I tapped the starter with a long pry bar and rubber mallet combo and it cranked right up.
it is now sitting in my driveway and hasn't stalled out for ten minutes or so.
Idles smooth.
I purged the Shrader valve on the rail. I don't know. I think there's bad gas in the car or something too.
I'm going to order the timing belt kit from FCP tomorrow morning and the iPD cam lock as well.
Hopefully then I can go ahead and be able to drive it.
Also, For fun, I decided to see if the A/C works. It does! To a point. When I put freon in, as it was low, the compressor made a LOUD noise after it fired up and bucked the engine idle speed down to about 400. What could that be? Sounds like the clutch is slightly seized. So, I'll go ahead and get a different one of those. Are those the same on the S70's? I can reshim it while it is out.
Also, how can I get a substantial amount of gas out of the tank so I can Seafoam it and fill it back up with magic premium?
Idles smooth.
#22
FPR are different on turbo and n/a
Timing belt http://volvospeed.com/Repair/timingbelt.php
PNP http://volvospeed.com/Repair/pnpswitch.php
#24
UPDATE:
I almost think that the FPR is bad.
If you release the fuel from the Shrader valve, the car is fine for a while, but will eventually stall out. Release it again and it runs.
You can hear the fuel pump whirring away in the trunk.
Thanks for the links.
After I tapped the starter, it hasn't malfunctioned. So, I'll replace that. Can't hurt to replace it since its an older car.
I may just order a new FPR from FCPGroton once things get a little nicer out.
First I'm going to do the timing belt. On FCP it says that the timing belt kit is applicable to certain serial numbers on the 94's. I punched it in for the 94 Turbo. Can I just go ahead and order the kit? I don't want to get the wrong thing.
http://www.fcpgroton.com/product-exe...ategory_id/201
#28
#29
I may buy the iPD tool just to have. Can't hurt and is cheap. I'd rather be safe than sorry.
Today, I went to the junk yard and got the passenger side fender gray trim that was missing and a new wiper arm. Along with most interior switches from the 95-97 models (A little more round and newer looking to me).
I spent five bucks
I also obtained the radio code from the dealer. The stereo POUNDS.
Once I confirm the timing belt with FCP I will order it.
When that is done, I will worry about the fuel issue. Something tells me its the FPR. Tune up will follow. Or, I may do the tune up after the timing belt job.
I spent five bucks
#30
#31
Werd.
The problem is that they're all GLT's.
Hell...they aren't even an LPT model...just N/A fail.
I swear, no one EVER puts new plug wires on their 850's. Every one at a yard has the original wires. There's a MINT wagon that was smashed on the side (okay, it was mint BEFORE the accident) and it has the original wires.
FCP never called me back today.
#35
#36
Indeed man. My wagon was fine, could have used a tune up, but it had all other necessary maintenance done.
Plus it needed more than this does.
When this car is done, I'll feel better about driving it, as I know it was done RIGHT.
I'll get pics this weekend. But the inside and outside are amazing.
I just hope I can get this thing going
