abs help needed
Old Aug 24, 2009 | 09:37 AM
sdc2000's Avatar
Default abs help needed
I have two 93 volvo 850 my abs light comes on with key and goes out like it should then after driving it comes back on and stays lit till car is turned off. I know I shoud be able to use the under the hood obd ut when I hook connecter in to socket a3 with key on it is always the light on diagnositic is lit what is going wrong please help
Old Aug 24, 2009 | 10:24 AM
fcpgroton's Avatar
Former Sponsor
This might help you out.
How to check A3 codes
Your problem is probably with the ABS pump. The system does a self check when you go over 20 MPH and if something fails in the check, like the ABS pump, it will turn on the ABS light.
piv15
Nov 3, 2012 07:56 PM
J Dubb
Jun 25, 2011 08:11 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
