ABS Issue?
Old Nov 13, 2010 | 09:16 AM
brianb's Avatar
Angry ABS Issue?
Hey guys...I'm having a weird issue here which sounds like my ABS. Under 35MPH, I will occassionly hear a buzzing like a motor and if I hit the brakes it feels like the ABS is kicking on. It only last for about 2 seconds. The ABS light is not on. If I did have a ABS module failure or ABS sensor failure, shouldn't the ABS light come on? I really have no idea what to check or what to look for. Any ideas?
Old Nov 13, 2010 | 10:14 AM
hookuspookus's Avatar
did you have brake failure ?
Old Nov 13, 2010 | 12:07 PM
brianb's Avatar
No, brakes have been working fine. The rears I replaced last year and the fronts still have about 50% left. No brake fluid leaks either.
Now that you made me think about it, when I did replace the rears last year, the rotors were right on the boarderline of being too thin (Chilton's said, I think, anything below 9.6mm should be replaced and mine were 9.7mm) Do you think if the rotors became too thin, it would trip the ABS? The weird think is that I heard that motor once or twice when I wasn't braking.
Old Nov 13, 2010 | 11:17 PM
brianb's Avatar
Does anybody know how many ohms I should be reading if I put an ohm meter on the ABS sensors?
Old Nov 14, 2010 | 11:00 AM
brianb's Avatar
Ok...Found the problem. The driver side ABS ring had some gunk on it that was covering 2-3 notches. The ABS sensor was also full of gunk. Cleaned both off with a dry rag (did the passenger side too which wasn't that dirty) and took it for a 10 mile drive with no problems.
Serge240
Mar 7, 2013 01:55 PM
piv15
Nov 3, 2012 07:56 PM
J Dubb
Jun 25, 2011 08:11 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
