ABS light
Old Nov 28, 2011 | 11:57 AM
Archie's Avatar
Default ABS light
For the last month my ABS light has been coming on. I got the following codes: 2-1-1(TCM Fault), 2-1-2(Short to voltage in #2, Shift Solenoid circuit), 2-1-3(No left rear wheel signal on moving off), 2-1-4 ? 1-4-1(Pedal signal faulty - Shorted to ground) 1-4-2(Stop lamp switch faulty)1-4-3-1(Kickdown switch faulty)I recently saw that someone had a similar problem but I have no idea what a TCM is or the best way to begin addressing these issues without going to the Volvo dealership
Old Nov 29, 2011 | 08:58 PM
jbuck's Avatar
Archie i would say you have too many codes showing up for an actual problem with each circut. It sounds to me that you ABS module has gone bad. The contacts need to be repaired or you can buy a repaired module off Ebay that has already be repaired. See the DIY section in the front. That my guess.
Old Nov 29, 2011 | 09:35 PM
TCM = Transmission Control Module
Should be one of the silver boxes under the cover of the big black plastic box under the hood over by the washer fluid reservoir.
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
